Electrical serious problems Need advice !!
Discussion in 'Mechanic's Corner' started by bigdreynolds, Dec 29, 2019.
  1. bigdreynolds
    bigdreynolds I'm too crazy to choose a custom title !!!
    Osage Beach Missouri
    I'm working on an 03 F150 supercrew . It won't start . Windows don't work , Radio don't work .Keeps blowing fuses .
    Fuse # 18 under hood = powertrain control module, fuel injectors, fuel pump relay, mass air flow sensor
    Fuse # 104 under hood = central junction box
    Fuse #1 under dash = audio
    Fuse # 3 under dash = cigar lighter, data link connector
    Fuse # 15 under dash = stop lamp switch , ( speed control , brake shift interlock ) GEM module, RABS module (sometimes can smell wires getting hot when that one blows )
    Fuse #22 under dash = air bag module, passenger airbag deactivation module
    If I unhook computer it won't blow fuses under hood but as soon as I hook it back up it blows fuse #1 .
    I removed computer and took it apart , no visual problems and no burnt smell .
    Steps taken so far
    Under hood
    Checked all grounds and battery
    unhooked all injectors
    unhooked all COP's
    unplugged mass air flow
    Inside
    Unplugged PATS module
    Pulled instrument cluster
    Removed radio
    Unplugged BCM above fuse box
    Pulled fuse box out and unplugged both wiring harnesses = not blowing fuse #18 under hood with computer hooked up .
    Hooked plug back up same results
    Hooked other back up and back to blowing fuse #18 under hood .
    got late and stopped for the night .
    Anyone have any Ideals ??
    What next ??
    I have several parts trucks to use any sensors , computer, fuse box etc. off of .
    I'm aware that I have to use corresponding Key and tumbler, cluster, PATS and computer to make it run . ( Been there and done that numerous times during cab swaps and other issues )
  2. OldCracker29
    My guess would have been a bad ground, but you said you checked that. Did you check the ground from the engine to the frame? A friend of mine had a 2002 F250 and it died on him on the freeway. Turned out it was the ground.
  3. bigdreynolds
    I will check all grounds probably be Monday afternoon at the earliest .
    OldCracker29 likes this.
  4. OldCracker29
    Good luck! :cheers:
  5. bigdreynolds
    I'm thinking I'm going to need it ! I think It would help if I could find a good wiring diagram to work with .
  6. OldCracker29
    "Google" can be your friend.
  7. OldCracker29
    :lurk:
  8. bigdreynolds
    I haven't been able to find a wiring diagram with free download anywhere .
    Does anyone by chance have one ?
  9. OldCracker29
    I can't remember, but doesn't a Haynes or a Chiltons repair manual have schematics for wiring? :dunno:
