door window on a 94-02 Ram 1500
Hickspanic
D-ville
A quick how to on replacing a door window on a Ram pick-up
First you need to open the door
then remove the 2 philips screws from the door pull cup
ther remove the philips screw form the mirror area
ther carefully remove the doow switch assembly, it will be needed to move the regulator op or down to access the 2 10mm nuts for the window
then carefully pull out on the bottom edge of the door panel to remove the door panel "christmas-tree" clips. Then pull the panel off the door.
Remove the 4 philips screws holding the speaker in place
carefully remove the water-shield, it will be re-used, so be very careful
then use the switch to move the regulator un til you see the following in the bottom of the door. Loosen but do not remove the 10mm nut
then loosen the front 10mm nut also.
after both nuts are loose slide the regulator towards the rear of the door to unhook the window. then work the window out of the door through the window opening. Install is the oppsoite of removal
COOL! :thumbs:
Nice write-up, Felix! Thanks! :thumbs:
Hickspanic
D-ville
No problem guys, I have to do the other side today.
Hickspanic
D-ville
it took longer to vacuum out the glass than it did to replace the glass.
Hickspanic
D-ville
no, it is my buddys truck. Got broken into twice in the last two weeks
grimey01
