Differential Fluid for my Z71
R
Riggs
i have never had a locker before and i hav a question on the type of oil i use.
Im thinking of running:
Rear - Mobil 1 Synthetic Gear Lube LS 75W-90
Front - Valvoline Durablend 80w-90 API GL5
why 2 different? cause the Mobil 1 stuff is about $10 a quart, and the vavoline is about $5 a quart.
Stick with the same front and rear. Down the road it will be simpler to "add" if you need to without having to remember what has what in it - plus the conventional will protect the diff just fine.
Texas1911
Son of the CLOWN
Austin, TX
Make sure your differential doesn't require a limited slip additive, and if it does, that the oil has it added to it already (some do) or you buy some of the additive to put in with the fluid.
Pumping gear oil into the differential SUCKS. It's a freaking workout since I had to use the little fluid pump thing. Fucking Germans.
DV2000NJ
The Browmaster
Central NJ
I just had to squeeze the little bottle. :D
Hell, I did it in the dark, just to make it at least a little bit challenging. :jester:
merlin5577
Taunton, MA
+1, and definately go synthetic. Royal Purple and Amsoil already include the LSD additive, if you go Mobil 1 or another brand you will need to add it yourself, depending on what you have in the rear. Good luck.
R
Riggs
i will just put that valvoline in, run it for a week and suck it out and change it again in the rear, and i will just put valvoline in the front too
Alljackedup408
Shut Up Stupid
Titusville FL
put synthetic in it.. if yah can afford it. What kinda drivin are yah doin with the truck? i know on our mud trucks down here we run the expensive stuff... ive seen the cheap stuff burn up waayyyy too many gears. but for everyday on road driving... valvoline is just fine.
grimey01
