Converting a D200 to a W200, worth it?
Lonesome7.3
By whatever means necessary …
Columbus, GA
I cannot believe I am the one asking this question. Usuallywhen someone asks about converting a truck like this to four wheel drive I tellthem it is better they just go get one that is already a 4X. After the time andexpense of doing it, one is usually always better off getting a truck that camefrom the factory with a T case. However, I have so much sentimental value wrappedup in this old Dodge and the overall truck is in such good shape I find myselfconsidering the possibility. I was just under it pulling the worn outsuspension components and it looks like all I have to do is cut the rivetsholding the two wheel drive cross member in place. Then I can fab up a simplerone to take its place. The biggest problem I have is I really do not want tomake drastic changes like that. But if I am to keep the truck forever, I wouldlike to make it a bit more versatile. Has anyone else done a conversion likethis? What are some pros and cons to just a swap?
tleach17
I wanna be your Maine Man
Central Maine
It sounds very involved but with a good donor truck it's a lot like playing parts swap. The is if the frames are the same. I have done a 2-4 wheel drive conversion with a friend. The difference was he had a leaf spring front end. Try to use as many factory parts as possible. Gabbing takes a lot of time. A good grinder and a punch and you can use the factory 4wd cross members.
Sent from my iPhone
Lonesome7.3
Columbus, GA
I have done a lot fo Fords, but they are pretty easy. This one, I am not sure about.
tleach17
Central Maine
I would try to find a 4wd and take some measurements. I wouldn't take a piece off the truck until you know the frames are the same. Don't go by people's word, the tape measure does not lie.
Sent from my iPhone
Lonesome7.3
Columbus, GA
I agree. I am looking at two options if I do this.
Getting a junk parts truck and going with all OE stuff.
Or, fab up a more modern coil spring set up with radius arms.
Cowboy Cadillac
Ain't no trash in my trailer!
Grande Prairie, AB, Canada
Go custom....diy4x.com would have all the suspension brackets you'd need, then just find an axle and tcase at a pick-a-part, ebay, craiglist or car-part.com
If you want cheap and easy....buy a 4wd chassis with a clapped out body and do a body swap.
Lonesome7.3
Columbus, GA
I have come to a conclusion with the conversion idea. I havebeen crawling around under the truck for a couple of days now. For the firsttime I have paid a lot of attention to the forward frame rails and cross member.I see a conversion would not be all that difficult. However, these old Dodgetrucks can be bought so cheap it is just not worth it… if you plan to go stock.If I am going to make that kind of change to my granddaddy’s truck, I may aswell go all out and drop in the 4BT I have been kicking around. So, if I doconvert to a 4X I will not use stock leaf springs either. Here is what I planto do.
Fist thing, I will cut out the rivets holding the crossmember in place. I want to remove it intact. Once the new engine it mocked upand the front end it sitting in place I will build a one piece cross member thatwill incorporate spring buckets. I will run coil springs, radius arms, and atrack bar. However, I do not plan to lift it. I want to run stock tires andkeep it no higher than what the truck would have sat stock.
Parts I want: I want to find a D44 eight lug from aChevy/GMC. Why a D44 from a GM? Because they are simpler, have no vacuum lock,and do have locking hubs. Plus, the diff is on the same side as Dodge ran backthen. As far as a T-case, I want a new process that bolts to the 727 in thetruck. I do not want to run an independent T case for this build. Hell, I mayeven keep that old reliable 318, who knows?
Jeff Dodson
