Compression on Cylinder 6
Discussion in 'Mechanic's Corner' started by davbell22602, Feb 1, 2017.
  1. davbell22602
    davbell22602 Stihl Chainsaw Man
    Bunker Hill, WV
    2000 ranger xlt regular cab automatic 3.0
    Engine replaced with engine from junkyard. Would get 0 on cylinder 6 for compression. Go drive it for awhile recheck compression get 100. Go drive it again awhile recheck get 0. Any ideas on whats causes this.
  2. Draenor
    Draenor KILL ALL HUMANS!!!!
    Is this with just a compression gauge or leak down gauge?
  3. davbell22602
    Bunker Hill, WV
    Compression tester
  4. Draenor
    I'd go with sticking valve.
    Can you perform a leak down test? This will confirm if it is a valve or not.
  5. davbell22602
    Bunker Hill, WV
    So how fix a sticky valve if thats what it is.
  6. Draenor
    Are you loosing power?
    You can try running some ATF or Marvel Mystery oil for 100 miles then do another oil change. If that doesn't work, then you may need to pull the head.
  7. davbell22602
    Bunker Hill, WV
    Not losing power but every once in awhile it spits n studders. But goes away after giving it gas.
  8. Draenor
    I'd try the leakdown test.
  9. PenguinLTZ
    PNW
    Burnt valve, bent valve.
    The gauge has a check valve, and it holds the highest pressure achieved. Not uncommon to hit a measly 100 psi on a warm engine with a burnt valve.
    Regardless, you need to pull that head
