That Crazy Squirrel
Actually, I'm going to go one further and say change the coax completely and swap it for one with a PL-259 on each end. That mount is setup for a PL-259 connection underneath.
The reason I'm suggesting this is because water infiltration is the #1 enemy of coax and you have an open end there. It gets under the outer jacket and wicks up inside, corroding the braid as it goes. On the cheaper coax, with a poly insulated center conductor, you don't have to worry about it getting into the insulation at least, but good quality coax with a foam dielectric absorbs water like a sponge if it gets past the jacket, making for a very expensive, but totally useless, piece of wire.
Those direct wire connections are not meant to be exposed to rain or weather.
After you change it, get yourself some coax-seal or some marine grade 3/4" adhesive heat shrink and weatherproof the connector even further.
. I am not the expert, you are. I needed a mount that works with my tonneau and my tonneau can be removed in under a minute (flat) from the truck. Would this specialty mount work with my current tonneau setup and speed of removal and installation?
