CB Coax routing / extension
M.Cueva
jrrod2004
Austin, Texas
Hey fellas, I finally got around to actually tuning my antenna with my CB in the truck (too lazy to do this prior) and I got very good SWR (less than 1.5) across the entire band. My problem is the coax length. That sucker is about a foot too short to where I permanently mounted my CB. I will have to take photos of my setup and post em here when it is daylight again but suffice it to say, I may need a "firewall bushing" for the rear of the cab since I know I can get that extra foot by going direct and then up instead of down and then up for the cab itself.
Details:
- Antenna is mounted on the right rear stake hole with the ground attached to the tailgate cable screw (nice and clean metal and direct ground)
- coax runs under the right bed rail cap due to tonneau on top - pops out near as the cap tapers off
- coax runs down the front of the bed to the right rear cab vent (and into it)
- coax runs thru vent housing to under the right rear panel (pillar panel)
- coax runs up right rear panel (under pillar panel) to roof (right rear roof side)
- coax runs under headliner on the right side of the cab all the way to the front and then ends almost a foot from the radio
- radio is mounted where the roof console used to be (console broke - another story)
CB is working only because I have the SWR meter hooked up with its "jumper" coax.
Thoughts on rerouting or other options that I may have overlooked?
(I know that pics would help alot - those are forthcoming tomorrow)
Probably need a pic. The way I see it run from the description, I'm not seeing where mounting the bushing will give you another foot.
You could always get a CB shop or yourself to solder in a new longer coax.
That Crazy Squirrel
N/A
Just get a double ended SO-239 and use the jumper you already have.
And, just FYI, with the antenna mounted at that location you're going to have almost no signal to the left rear, but a good signal to the left front.
Here's a diagram illustrating how location affects signal:
dirtyoldman
Saugus,Ca.
I was thinking the same thing but I wanted to see what Bernie had to say about it.
M.Cueva
jrrod2004
Austin, Texas
Thanks fellas, I will grab pics for yall shortly. The antenna gives extremely high swr near the cab (either front stake hole). I tried the rear and will very little tuning, I got it under 1.5....
Sent from my HD7 using Board Express
That Crazy Squirrel
N/A
What antenna are you using?
M.Cueva
jrrod2004
Austin, Texas
Using a Vanco 4 ft antenna (regular, not the high performance)
Have a firestik tip tunable 5 foot antenna that does the same thing so I figured that I would rip up the cheaper antenna
That Crazy Squirrel
N/A
Okay, looking at the pics I have three suggestions:
Move it to the driver's side (less chance of it hitting someone on the curb or roadside trees/brush)
Run the coax down through the stake hole and then under the box rather than over it.
Change the coax for a longer piece if needed. (It's pretty easy to do on those mounts)
Mrjvieira
