Cam advice
63chevystepside
High speed low drag.
us
Iv got...1977 010 block 454 30 over,2bolt block,nodular fetus crank,truck rods with arp bolts, been balanced with 9.5:1 pistons,781 heads. Everything is fresh just got back from my builder. Valve springs good up to 550lift. Its all going in a 83 long bed or a 85 swb. 400 transmission and 3.08 gears. Max rpm I wanna run it is 6000ish. What cam do you guys suggest?
What do you intend to do; Tow, Race, DD? Have a converter installed yet? Stall speed?
I'm no cam expert, but a lot of factors come into play on selecting one.
3.08 gears? Damn. You will need to stall the shit out of anything huge.
at 6000 rpm in first on that 400 you will be going 50 :p
