Thought I would post this for everyone to check out. That is for those that have cabin air filters. Here is a cool guide on how to replace your cabin air filter. You will need to know the Wix part number of your cabin air filter. Once you have that you can look it up and it gives you a basic guide on where yours is located and how to accomplish it and the time it should take to change out.
If you need to find out the wix part number of your cabin air filter you can look up your vehicle here. This will give you the Wix part number.
Or that the screws for the retention clip are different from EVERY OTHER standard or metric mini socket known to man(that you thought you had) and you will have to buy ANOTHER one.
Once that screw was very loose and the other 2 screws were out, I could swing down the panel enough to gain acces to the air filter housing. Mine was very dirty as well, probly the first time its EVER been changed. Heres how mine looked compared to the new one.
