gsta86
Caused myself some problems, ended up not being able to start the truck.
Fast fwd 3 days, got everything wired back up, new ignition module, wired in the battery, ignition, accessories, and signal wire from starter. Turn key to acc and I'm semi good. Used a test light and have power to everything but signal. Normal right? As it won't get signal until I actually turn the key to start.
But when I do that, I get nothing. No crank, nothing at all.
But when I hook up a remote start to the starter ( + & signal post) the damn truck starts right up.
What am I missing? Bad signal wire? Solenoid should be fine right, due to the remote start switch working?
Help!
Help!
