Big 3 Upgrade
Discussion in 'Technical' started by stadt11, May 21, 2009.
  1. stadt11
    stadt11 LetMeGoogleThatForYou.com
    Central Iowa
    Just ordered 1/0 gauge welding wire from WeldingSupply.com to do this upgrade (my volts drop down to about 11 or 10 when I rolling up/down the windows & sometimes on loud bass hits). Shipping only took 1 day to receive.
    This was much cheaper than getting actual power wire, total cost for 4-ft red 1/0 gauge & 8-ft black 1/0 gauge & 8 1/0 gauge ring terminals was $45.
    Waiting on my 200amp fuse from eBay to get here in the next couple of days & just gotta find a time to install it all and will post before & after results.
  2. Zembonez
    Is that multistrand wire? got a pic of it?
  3. stadt11
    Central Iowa
    Welding Supply gets their cabling from Direct Wire & Cable.
    Here's a pic of the strands:
    [​IMG]
  4. Zembonez
    WOW! That's a great idea. Looks like it would make a fantastic amp power lead.
  5. Riggs
    Riggs Guest
    i did this in my truck... it really helps out.. my volt meter is a full 2 ticks above the 14 mark...
  6. Z71 Kris
    Z71 Kris Independence...
    N. East Ohio
    riggs, the new rims look great, sorry for the hijack, now on topic, I have been debating this for a while now. The only problem I see with this upgrade is people using a higher amp fuse then what the alt puts out. If your alt puts out 145 amps, what good does a 200 amp fuse do? I thought the Idea of the fuse is stop current over load to reduce fire(from the wires) and parts malfunction(alternator). Wouldn't a 160 or 165 amp fuse make more sense, then you have some room for overage but not say 55 amps, does that make sense? I know for power wire the fuse I have in there is 10 amps above the draw of my amp, as to not worry about the wire catching on fire from over load, or blowing the amp for that matter. What are some of your takes on this.
  7. stadt11
    Central Iowa
    I thought the same thing, but talked to several audio guys and they said the fuse size should be based on the capacity the wire can carry.
  8. Bigredmariner
    I've been told the same thing and have read it also. For most marine applications we fuse to protect wiring and have motor overload thermal disconnects ( same theory as a circuit breaker) to protect equipment.
  9. JennaBear
    JennaBear Sponsor
    Sandy Eggo, CA
    Why not just an overdrive pulley for your alternator?
  10. yota.coma
    yota.coma undercover cop
    sylacauga, AL
    I did the big 3 awhile back along with an iraggi 180amp. My voltage never drops below 14.3, and charges at 14.7 consistant
