Best way to charge a GMT900 truck's battery
Discussion in 'Technical' started by 07blackz71, Nov 23, 2011.
  1. 07blackz71
    07blackz71 Change is always Good!!!
    Cedarburg, WI
    My battery is low on my Tahoe and would like to use a battery charger to get back to it's full charge. I never had to charge a NNBS trucks battery yet and am wondering if I have to be careful so I don't mess up any of the electronics. On other trucks I never unhooked the battery from the truck and I just hooked the charger to the battery cables on the post. Would this be ok to do on my Tahoe also?
    I know it is probably a stupid question but I don't want to mess anything up before turkey day. I have alot of running around to do tomorrow.
  2. Zembonez
    Re: best way to charge a GMT900 trucks battery
    Hook the positive to the post and the negative to a ground. Make sure the charger is off when connecting. It'll be fine.
  3. drperry
    drperry Fox 1! Fox 2! Fox 3!
    Is your alternator not charging properly, or did you just leave the key on or in accessory running things for awhile?
  4. Texas Jim
    Texas Jim Texas..It's a Whole 'nuther Country
    Ft. Worth
    I have had to use the charger a few times on my Cadillac...
    I hook up the cables from the charger and then turn it on low for a little while...
    If that isn't enough, after two or three hours, I turn it up to high.
    SO FAR it has never hurt anything...
  5. drperry
    If all you do is a lot of short trips, it's a good idea to throw a trickle charger on it overnight now and then.
  6. 07blackz71
    Cedarburg, WI
    Thanks guys
    I was messing with my radio and a wireless back up camera with the Tahoe off so it drained the battery to the point that it had a "service charging system". It had enough charge to just barely start it up. So I drove it around for a while to get some charge back. But I only drive 10 min. to work so it is not fully charging. I checked it and it only shows 10.6 volts after sitting overnight. I also load tested it and it showed it was ok.
  7. drperry
    That wouldn't wreck your battery, you're safe there... But a little charging is always nice :)
    Like JIM said... Positive to positive, negative to a good ground... Engine block works.
  8. Zembonez
    I've had to charge mine several times over the last two years due to it sitting in the garage for months at a time. Last Winter, I put a new battery in.
  9. 07blackz71
    Cedarburg, WI
    Well I just hooked it up and I am just doing a 15amp charge to get it to a full charge and then maybe this weekend do a trickle charge to get it a more deep charge. If I have more issues I guess I will have to upgrade to an interstate battery.
  10. drperry
    I hope you're not leaving that 15 amp charge on there too long :D
    I prefer lower charge levels so I can go do other things and not have to worry about it.
    Unless your charger has an auto-cut off :thumbs:
