I bought a restored 1973 CJ5 a year ago. Here it is:
And as usual, "fully restored" never is. It did need some minor work. It has a "new" (not rebuilt) 304 V8 long block that the person that did most of the restoration work had found as a never used crate motor. But he had bolted all of the old accessories on it. So, it had 5 vacuum leaks on the carb, the air filter housing was too low and interfered with the choke linkage, and the alternator mount needed redone, so the alternator didn't flop around as the engine was running. And there were 4 oil leaks in the engine/drivetrain. Things like the seal where the oil pump bolts to the block were leaking. You can't buy an oil pump seal anymore without buying and oil pump rebuild kit, so the oil pump was rebuilt. The input and output seals on the transfer case, and the input seal on the rear differential all needed replaced. While the transfer case was out, it was rebuilt as well. We found that the gears and bearings were in good shape, but the shift rods were bent, and were replaced. Now a year later I would consider it "mostly restored". It now has the state required no fault insurance on it and will be registered this week. I plan on just driving it for fun on sunny days and will put it in the local car show on July 17th.
