Adam's Super VRT Tire & Trim Dressing = Awesome!
07FX4Chick
LIFETIME SUPPORTER
Des Moines, WA
I spent about an hour on each tire on the Ram. It's very easy to apply. :thumbs: (Well, except when you have all these little divots on the side, like on these tires. :fume: That is why it took me so long.)
I think it makes the tires look brand new. There also is no spray up when rolling, like other products. I am impressed. :D
Just washed / dried:
After application:
That do look good!
fortplainman
Custom User Title
upstate ny
your telling me i love the stuff. just make sure you put it on a clean surface. if wanting to reapply, wipe cleaner down on the surface before you put on a coat of SVRT then wipe down afterwards with a MFT. thats how i do it so it wont run if it rains.
How much does a bottle of that stuff cost? :dunno:
I may need to get with Jarrod and try out a bottle of that stuff. I like the fact that it has a sheen to it, but it doesn't look overly greasy or like its dripping wet. Also, does this stuff ever sling off and get onto your fenders or rockers when driving? I have had that problem with Black Magic Tire wet.
Carolinaboy
Bluffton, SC
The best thing about SVRT, is that it makes the tires look just "right" not greasy and not dull
Not mention it will bead water like crazy at first.
Shanin try it on your monsters after you clean them and dry them! It makes them look incredible & it will bead water too
Did you use APC on the tires first? I noticed an even better after effects when I did that
