A future plan??
sand man
what do you guys think about these with twin 52-60mm turbo's?
they are 1.7/8" to 3" v bands :hmmm:
cost, less than 500+ shipping
sand man
I bended 2 intake valves and 2 exhaust valves on my #3 and #5 cylinders
and the cam just dosent make enough power to please me any more, and im looking to kill an evo 9 with mods and by god ill do it:lol:
sand man
will its not going to be done any time soon, just thinkin out loud.
the truck is at my uncles shop to change the valves and bolt everything back up
i starts saving up and buy parts on the tax time this year so i can get offers for the sponsers on PT.net
Alljackedup408
Shut Up Stupid
Titusville FL
Jesus.. how did you break valves? You over spinning it.. or is the valve to piston clearance not sufficient enough? lol.
sand man
spins at 6600 max and 6400 shift point
actualy this happend befor i knew the valves were bend
this is what happend, the head of these spark plugs fell in the cyl # 3 and 5
ill remove the head tomorow. i reinstalled my old iridums
what is the cause? are the copper cores not compatable with my setup?
well, the head is off the motor , the cyl looks perfect ,like nothin happend.
the valves look rusty , i think there is some kind of cyl pressuer leak.
will check the valve seating on the valve port and check the valves for any damage.
thats it. thanks for posting guys
as for your questions these valves are less than 25 miles old
the timing was programmed in iridumes thats why( i think)
but why only 2 out of 8 are bad???? btw they are 3 and 5
i used AutoLite XtremePerformance Iridiums and they are way better than NGK laser iridiums IMHO and they last longer
the heads are off foxxer
the damages so far ar 2 intke valves and two exhaust valves
ill buy them tomorow,
any other direct replacment?
how about stock ls6 valves
my old plugs wich were iridiums lived will for at least 20k miles with cam and befor cam
with alot of spark advance
my afr is good , pritty sure about that
got my new valves orderd still wating on them to arrive
gtm96
