Hi There,
I was recently gifted a '78 Chevy C10 truck with the complete maintenance history and it has less than 100K. I'm wanting to use it here on the land and make it available for friends to use for projects. Before I am comfortable doing so I need to resolve a couple problems. Being somewhat mechanically inclined, I'm happy to try and fix it myself. If its more complicated, I'd like to understand it before I pay someone else to do it.
The first issue is that I can't put gas in the tank without it spilling out at my feet. I changed out the fuel hoses, both filler and exhaust, and still have the same problem. Actually it seems to be worse. There are two tanks--same problem on both sides. The exhaust hoses were pretty cracked up before changing. Previously the gas leaked out from the underside of the body. Now it wants to leaks down both sides of the body. I realize now the hoses weren't the issue though its good to have them changed. I was considering changing out the filler necks but after some research that doesn't seem to be the issue either (even though they aren't sealing, hence the leaking fuel). I believe if it did seal, I wouldn't be able to put any fuel in at all. The pump would just shut off. It seems the air is not able to get out of the tank when the fuel goes in. I see that newer models having this problem when the fuel tank vent valve is clogged but from what I can tell the part is not available for this year of truck.
My question is, is there something equivalent to the fuel tank vent valve for the '78 C20? Is there some other emissions apparatus I should be checking? Any other ideas?
The other issue is that the door has to be SLAMMED a couple times to close it properly so it won't rattle. From what I can tell, changing out the hinges should remedy this. There doesn't seem to be a spring so it should be pretty straight forward aside from supporting the door properly and wrestling the pins out.
Am I missing anything?
Many thanks for your input!
Cheers,
Laura
Cheers,
Laura
