2010 Chevrolet Silverado Information
2010 Chevy Silverado official site.
http://www.chevrolet.com/pages/open/default/family/silverado.do
99chevy7.4L
Bowtie Enthusiast
AL
Hi seen something interesting. In the 3500HD CCLB 6.2L I think I seen 6speed dually of course. the curb weight is only 6274. How is that possible. My CCLB weighs 8050. Are the trucks getting lighter. I dont see how that would help.
I see 6404 for the '10. The info I found on yours is...or close to it....
Base 4x2 Crew Cab 8 ft. box SRW
Horsepower:255 @ 4,600 rpm
Torque:330 @ 2,800 rpm
Transmission:5-spd man w/OD
Curb Weight:5,509 lbs.
Fuel Type:regular unleaded
I dont see where you are getting 8050.
99chevy7.4L
Bowtie Enthusiast
AL
Mine is 99 C3500 (LS) Crew cab DRW 8ft box 7.4L big block as it is the Classic body not the later half of 99 when they went to the LS series engines.
99chevy7.4L
Bowtie Enthusiast
AL
My GVW in the door jam is 10,011lbs pounds also. Engine: 290HP/ 410ft/lbs torque, 7.4L vortec, 4L80e Automatic Transmission,
GVW is the loaded weight, curb weight plus payload.
Sorry.. I forgot that..I used the 350. The 7.4 is 10011(by your sticker) - 3803lbs (spec I found) payload capacity is 6208lbs. Which sounds better. :thumbs:
Available Engines & Transmissions
Crew Cab Long Bed 4WD
Engines
5.7L V8 Opt.
6.5L 195 hp V8 Opt.
5.7L 255 hp V8 Std.
7.4L 290 hp V8 Opt.
Transmissions
4-Speed Automatic Overdrive Opt.
5-Speed Manual Overdrive Std.
Payload & Towing
Passenger Volume (cu. ft.) No data
Cargo Volume (cu. ft.) No data
Standard Towing (lb.) 6500
Maximum Towing (lb.) 12000
Standard Payload (lb.) 3325
Maximum Payload (lb.) 3803
Standard GVWR (lb.) 9200
Maximum GVWR (lb.) 10000
:wtf?: Scott? You should've waited another 16 days...then it would have been a year old. What were you thinking! :jester:
grimey01
