2000 SILVERADO LED DASH
Scottyboy has done several of them, he usually checks in regularly. I'm sure if nobody else can tell you then Scott will be able to help you out.
Shanks12
Will You Join My WolfPack?
Fishers, IN
Welcome Man... Wish I could help ya out.. I've never changed them out myself, so not sure on the size
1LOW4X4
Use the 3mm flat top leds in every panel. In the cluster, just double them up, two to each hole.
They look better than the 5mm.
The 5mm were too dark, as you can see in this pic, they are in the cluster
BeaGeiger9
