2 Cycle Oil In Your Gas Tank
Ramjoe
Moderator
Northeast PA
hmmmm....I don't feel like having my truck smoke every time I start it up. Maybe thats just me.:dunno::lol:
R
Riggs
well they are doing it with adding 4oz for every 5 gallons which comes out to a 500:1 ratio or even higher
apparently its supposed to:
lube fuel pump
line fuel lines
lube ring pack
make a better seal for better compression on the ring pack
lube upper cylinder
i am actually trying it on my truck, so ill let you know how it turns out
Don't suppose a tiny bit could hurt anything... but I'm not sure of any benefit either. :dunno:
If you put very much in, the catalyst could be damages along with O2 sensors. I'd be careful adding much.
V
Vmax2007
Gas already has all of the additives it needs.
I call :bs: on any benefit.
What kind of negative impact will this have on the injectors? Probably minimal on a TBI, but I wouldn't take the chance on the newer MPI systems.
Remember, just because it "sounds" logical and a few people on the interweb are doing it does NOT mean it's a good idea. There are engineers that design these systems that know a helluva lot more about them than we do, if they didn't design for it, I wouldn't use it.
DV2000NJ
The Browmaster
Central NJ
Sounds like a bad idea to me. With a ratio that lean, how much could it possibly help? Do I think it'll damage anything? Probably not, but your fuel system isn't designed to have 2 cycle oil running through it. :dunno:
I haven't heard of it but I have heard about the Marvel Mystery Oil thing. I tried it and saw no improvements. So I stopped using the MMO.:dunno:
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
thats how we break in our river boat engines, but only for the first tank.
grimey01
