Back to engine work, I'm keeping the old huge GM direct drive starter.
Worked super well on the mouse motor ..
Had the thought of freshening up since it's got a few years on it ..
That endeavor went well with finding a cast iron housing that GM made for Hi-Performance big blocks in the late 60's and early 70's ...
Direct replacement for the aluminum nose ..
Had to hunt down the bendix fork cause the aluminum nose fork is different ...
Found a fork from a starter that was used on a 58 283 ci Impala ..
It was worn some as you can see in the above photo ..
Got a Nos fork coming from eBay ..
Replace the brushes, bushings and got a new solenoid ..
Cleaned up the armature and did all the checks to it ..
Starter worked good as new, but .....
The rubber grommet was about done ..
Since my hands are into it I hunted a new one down ..
Being the starter is over 50 years old, no part store had it ..
They said it was a vintage part ..
Made a trip 10 miles up the road to a old starter/alt. rebuild shop and that was a adventure ...
After all that fuss was done & over netted a Hi-Po old school GM starter ..
Waiting for the eBay fork to show up..
Starter will be done, done, done !
Got enough leftover parts to build another one ..
