Well I'll Be Damned,Wifey's Burb Is Alive(How To,Kind Of)
dirtyoldman
Saugus,Ca.
Well after hours & hours of work on her Burb I finaly got it all together & after cranking for maybe 4-5 seconds it fired up and idled smoothly and after taking it for a test run it's back to it's old self,which is a good thing :thumbs:The problem is my Sony camera took a shit while putting it back together so I didn't get alot of pics,most of 'em were on the internal memory & I can;t find my cord.I used my backup camera(Kodak p&s)to get a few but not enough to do a real good ''how to'' thread but I'll try....
After disconnecting the battery I just started removing hoses,tubes,wires,etc.No mystery here
I removed the air filter to throttle body intake tube as an assembly
[/IMG]
[/IMG]
Removed the throttle cables and moved 'em out of the way
[/IMG]
Drain the radiator down enough to remove the hose from the thermostat housing(no pic)
BIG TIP....undo the connections from the A/C compressor,remove the four bolts securing it and ''fold'' it out of the way.It sits nicely over on the coolant recovery tank :thumbs:
[/IMG]
[/IMG]
Once you can get to the rear of the engine remove the 1,3,5,7 spark plug wires tuck 'em out of the way,remove the cap & tuck it out of the way,unplug the wires going to the distributor.Then you can access the fuel lines.Use a tube wrench & a backup wrench to loosen & disconnect the lines.There is one bolt(can't see it in the pic)that holds the fuel line bracket,remove it and be carefull not to drop it :jester:
[/IMG]
There are two small nuts holding a bracket on the other end of the fuel lines,remove the bolts & bracket and gently pry up on the lines,pry & wiggle at the same time and they will come out(no pic)
Remove all the bolts & studs(10mm deep socket)holding the plenum then lightly tap the plenum with a plast or rubber hammer,easy to tell when it's loose by the sound.Pull up on the plenum,the fuel injection module might stick a little but a light tap of my plastic hammer lossened it and the plenum came up & off(no pic)
Then you have a clear view of the old spider.Remove the injectors by squeezing the tabs and pull 'em out(they come out easy).Put a screwdriver on each side of the module releasing the holding tabs and push them apart,the module will pop out with a little wiggle.(no pic :()and you'll have what you see on the right
[/IMG]
A little cleaning and it's time to install the new module...
Install the new bracket & set the new module in it,move the new injector lines a little to allow the module to snap into place.Then orient the injectors for each cylinder.Important!!!#s1,2,7& 8 must go in first as 3,4,6 & 5 go over them.The injectors don't have a real definite snap when locking into place,it's more like a slight resistance
[/IMG]
From then on it's a matter of reversing your steps to re-install everything.
Finished
[/IMG]
[YT]ahSIypL87Kc[/YT]
I could of done a better ''how to'' if I had access to all the pics I took on my Sony p&s but it took a crap on me,sorry :(
It really wasn't that bad just time consuming for my first time accessing the injectors.Next time it will go much faster :thumbs:
1999 GMC Suburban K1500 5.7l
Conversion from CFI to MPFI
Delphi p/n:FJ10566
Frikkin Awesome Gary! :thumbs:
Awesome! Those 350's were fun to work on, especially back in the day. :thumbs:
