Scangauge II install in 02 Silverado overhead console
I purchased the Scangauge II and love it. I have it set up to read transmission pressure, temp, oil life monitor since mine only has a light that comes on when it is due and doesn't show the percentage. I also set it up for all kinds of trip stuff, like current distance to empty, today distance to empty and so forth.
I mounted it in that blank in my center console. I figured it was the best place for it. I just had enough cable to make it there.
I first traced the outline of the scangauge and then cut it out with a dremel.
Then I ran the lead up from the OBDII port.
Then fished a wire over to the center console to pull the lead through to it. I used some .032 safety wire for this. A thicker wire would have been better but I managed to get it to fish over. :lol:
Then I just mounted the center console back up and slid the scangauge into it. I made it a little bit of a tight fit. This way I can take it out if I need to use it in another vehicle to scan codes. I just need to get another cable. So I'll be looking on line for one here shortly.
Looks awesome! :thumbs: I wish I could mount something there but thats where my rear AC controls are. :uhoh:
Shanks12
Will You Join My WolfPack?
Fishers, IN
looks good man... I love having my Scanguage!
My 4 that I am running now are Trans Temp, Water Temp, Air Intake Temp, Mileage Remaining
Very nice. Looks like a factory install!
Codeman
It will all be worth it.
Vegas
Damn nice install! Ordered the scangauage today, thanks Nick.
